Knuckle groove?
BOISE, ID
Is it normal for the knuckles/steering to ride in what feels like a groove? I was about to pull the knuckles apart to rebuild and I started moving them sided to side to check them and it feels like they fall into a groove that seems dead center. Hate to pull this thing all apart if it doesn’t need it. When I spin the hubs they feel really smooth too. Tried attaching a video but not sure if I can. Hope what I’m saying makes sense
It is possible the knuckles are grooved, but if thats the case, you should be able to see the groove when you turn to the extreme either way, as it typically is around where the felt wipers are.
That sounds like its the bearings on the top and bottom of the knuckle. You'll need to change out the bearings and races. Not hard, just messy. Lots of tech tips on this site to get it done.
Can’t see anything when I turn it
Search "fj40 knuckle bearing replacement." Either on mud or YouTube. Lots of good step by step instructions. Like I said, not hard, just messy. And You'll want to change the wheel bearings and seals while youre in there.
Thanks. I’ve watched a few of them so far.
Curious if you guys know what kind of hubs these are? The vids I watched look completely different now that I have this thing off
The lower trunion bearing races will have flat-spots. The vehicle spends most of it rolling time pointed in a somewhat straight line. The lower bearing rollers pound themselves into the races. This is why the trunion bearings should be replaced every 60,000 miles or so.
Same here.
The shock mount pin could use a little love.
