Knuckle Grease
So grease with moly is slicker then synthetic multipurpose bearing grease like green lucas 10330 x-tra heavy duty. The Lucas green has the factory recommended NLGI #2 rating for the birfs.
So the green Lucas x-tra heavy duty to pack the birfs and what abbot the Lucas red n tacky for the bearings?
You need to use lithium soap based grease with at least 2% moly content for birfs. that lucas both red and green would be for the bearings only.
Thank you. Spent about 3 hours last night on this topic geez...I know more about moly and lithium than I ever thought I cared to know! Thinking the palladium for birfs and just something like mobile 1 synthetic since both are readily available at the local stores.
Sounds like you got it sorted out. Used to be a good thread on all the grease and there moly content but im not sure where it is now.
