Knocking under valve cover... video
Ea.Wa.
I am not an engine guy, well today I guess I am...
Friends '97 FZJ80 150K came over today with a knock, after inspecting it is definetly under the valve cover, front of engine... oil pressure is 1/4 at idle, 1/2 w rpm on dummy guage. Runs great still!? Pulled plugs/wires all good not isolation while pulling wires at idle. Pulled valve cover, all *looks* good? No smoking gun... cranks like a sewing machine with no noise, lobes all look good?
Timing chain tensioner? Lifter? Piston slap? Seems like the knock lags a split second w RPM change
Thanks all in advance!
He says plugs were tight upon removal, plugs are not new says about a year old, but quite a few miles- just look like a lil ash from burning some oil... electrode a lil disolored (pink-ish) but I've def seen WAY worse!? Am I wrong??? Thanks
Did you check the valve clearance?
The Camry is making same noise and it has one exhaust valve that needs adjusting. It has the same setup of valves as the 80.
Does the noise go away at higher rpms? The Camrys does.
Do a compression check. You can rent a tester from AutoZone. Also a cylinder will make that noise if the combustion isn't correct. Check the distributor cap/rotor/plug wires for a bad contractor which is not fully firing that plug.
So compression #'s are
185
190
190
185
192
195
Ran it with valve cover off, I DO NOT recommend this!!! lol used a stethascope to locate... could NOT!? timing gear/chain *seemed* fine as well as all cam bearing caps. startup cold did not make knocking sound, once revved it did again, new plugs now as well...
I would pull the belts to eliminate that noise. It may help you hear and pinpoint it. (Especially in the video it makes it harder to hear.)
If compression is fine, MPG is fine, not burning oil, etc etc etc than I probably wouldn't worry about it and just run it. :meh:
Yes, Remove belts and try your stethoscope on the power steering pump.
Im curious if the sound is coming from under the valve cover how the power steering pump would be involved?
Belts
10-1 it's just the belts or pulley, my guess is it is the belts. The belts separate on the inside and chunks come off. The noise is from the damaged section running through the idler pulley making that god awful "my timing chain is about to rip through the case" sound. Pull the belts and start the engine you will not hear the noise. Then you can exhale, grab a #6 and put on OEM belts this time.:steer:
PS I just did the exact same thing yesterday with my brother-in-law's 80. Same noise, sounds like it's inside the engine/valve cover etc. My b-i-l even took it to his mechanic, mechanic said he thought it was the timing chain and was ordering the parts today to replace it for $2K. Glad he and I second guessed the diagnosis by the "pro".
I chipped the gear on the power steering pump when rebuilding it. It made a hell of a tapping noise. Polished the gear, it still tapped. Replaced the gear and noise gone.
Any of the drive gears with a chip in them would make a ticking noise.
Just ruling out the easy fixes before the $$$$ ones.
Gotcha. Just didn't get the correlation :) this is why this forum is great :)
Any conclusion to this engine noise? Did you ever find out what it was? I am now having the same problem: loud tapping under the valve cover with no loss of power and goes away above 2000 rpm.
did you figure out what was causing the tapping??? mine started tapping a day ot two ago and i hope its not anything major. gonna check today.
I'm so relieved i found this and it wasn't a valve or something expensive. the belt tells me that its time to do some preventative maintenance right now before i get stranded somewhere.
That's not an oem belt. Oem is a v belt which fits perfectly in the pulley grooves. A toothed gates is probably a better quality belt but will be nosier. Congrats on solving your issue. Wish most of mine were this easy.
Buck
I realize this is an old thread; so, I'm hoping that means you've solved the problem by now or it's been going strong for 30k miles and who cares... I'm having a noise that sounds exactly like yours and seems to be coming from about the same place in the valve cover. I removed my belts to no avail. Any updates on yours?
