Knocking sound in neutral...?
spdwaver
Formerly Kalifornistanian
Caldwell, Idaho
Hello,
I am new to this site, so please bear with me. I have recently purchased a 1966 FJ40 that is about 30% Chevy (327 Engine, SM465 tranny) and an Orion T-case. I did help assemble alot of this cruiser with my dad, but I am not as knowledgable with this certain issue.
I am having an issue with a hard knocking sound when rolling at any speed, while in neutral. This sound does not occur while giving it gas, only while slowing in gear, or when rolling down the road while in neutral. The knocking sound is very loud and can be felt, and is relative in frequency to the speed I am travelling. Other than that, the forward motion while stepping on the gas does not produce any ill-desired affect whatsoever. Does this sound familiar to anyone?
FYI: the rear end is fully locked with (i believe) a Detroit locker. I may be incorrect on exactly which tranny is in there, but it is a Chevy four-speed with an incredibly LOW low gear.
Any help with this would be greatly appreciated!
I'm guessing a bad bearing at a connecting rod(s). To check it out, pull one plug wire at a time while it's idling and see if the noise goes away. That will be the offending bearing.
What oil pressure are you getting? If bearings are starting to go, the pressure will often drop due to the increased flow thru the bearing surface.
I don't know how the Chevy engine fits in an LC, but if you can drop the oilpan you can replace a bearing without much trouble. I did this on an old Impala and got another 7k miles before I pulled the engine for a true rebuild.
L
Welcome.
If the sound only occurs while slowing down, or coasting it will not be an engine bearing....as a bad bearing in the engine will make that noise all the time, especially under load.
I would look at the engine and trans/tcase and verify that they are snug in there mounting positions...also, I would look at your driveline.
Good luck!
-Steve
Thank you for the rapid response guys! WOW!
I must clarify one thing...the engine is not the issue at all. There seems to be alot of play (even though all is tight) as a backward and forward motion, best heard if you are new to a clutch, where the vehicle is in a jerking motion. That is where the clanking is most prevalent. I just tested the theory by turning off the ignition as it was rolling..no noise, no clank. Well, guess I will do what anyone would have to do in my position...take it apart and put it back together again.
Thanks again for your help.
Thank you for your speedy response..
I had better go through and tighten all hardware to ensure that nothing else is loose...problem is is that this is my transportation home from work tonight, and I may not make it. This would be my first "real" run since it was built. But that noise is really a threat in my opinion, as it can be felt throughout the cab. Is it clutch related? Maybe the fork?
It varies with road speed, not engine speed. It almost seems to be coming from where the t-case meets the tranny...but I also need a proper place to check the u-joints (I am at work now) which may be the problem. Let me rephrase: this sound is similar to the sound and characteristics of u-joint failure, which leads me to believe the joints may be the problem. BUT...there has been an ongoing problem from the beginning with this tranny...rebuild after rebuild, differing issues each time. My dad said that all was ready to go since he put in the Orion t-case, but the noise is getting worse as I test it every hour. I cannot seem to pinpoint it, so any suggestions would definately help.
I thank you all again for the advice...and speedy replies.
Thank you for the engine advice, Azlar...that was also a concern at one time that I may face in the near future. Oil pressure is great, and steady. Temps are fine as well (even though it is 104 degrees here).
Thanks
spdwaver1 said:
Hello,
Lets see....
I just read through this and noticed that it happens relaitve to the speed you are traveling and that it does not make the noise under power, only coasting.....
Is your fire extinguisher secure?
Do you have any empty or full beer bottles under the seats?
Thanks Steve...I will try all of that! And I will check all of the fluids...again. Another question, if I may: Since there is a type of locker (ratcheting) in the rear as I mentioned before; is there a special oil type that should be used, as opposed to 90 that is in it now?
Thanks again..
Very thought-provoking question, and very intuitive. I do not have a fire extinguisher (yet), nor are there any bottles (remaining) rolling around in the back. But I did notice, after test run #6, that the sound can also be made by pushing IN the clutch really fast...the clank seems to reverberate at least three times.
Updated info. on the FJ40..
As I mentioned before, I was not sure on which tranny is in there. Well, it has an SM420, not an SM465. Also, the locker is a Lock-Rite, the only one that could be installed into that year; not a Detroit as I assumed it was.
Does it only do this while you are turning or does it do it when you are going straight.
Does it do it especially when turning in parking lots?
Did it just start doing this or has it always done this?
If it not a loose slip yoke on the drive shaft, I'm thinking that you are discovering the normal operation of a lockrite.
