Knob versus shifter on t-case
A balanced city
Ok so all the 4wd vehciles I have owned had a shifter for the t-case...Now I am thinking about buying a Tacoma and see there is no t-case shifter ....just a dial...should I be concerned or has Toyota made this work and work well???
I sure hope so. I had a push button 4x4 switch on a Ford Explorer that would freeze on cold mornings-the times I really needed 4WD. My Tacoma has the transfer case shifter. Is this on the new model?
I haven't really done much research cause I am still in the early stages of trying to decide if I want a new or slightly used Tacoma...But the whole shifter is more appealing to me... Thanks for the info on the year change
My Tundra had the push button 4hi/4lo set up and it hasnt failed me yet. I do have the extended warranty so when it does:flipoff2: they can fix it!:p
Ive also reserved to the idea that when the warranty is long gone, I will go to a manual setup.
I have had no problems, and I was certainly skeptical when I bought mine in 05.
It sure is nice to be able to go in and out of 4WD, moving or stopped or WHENEVER!
I had a 98 4Runner with a push button 4WD that would sometimes give me troubles (of course when it was pounding snow outside!). My 02 4Runner had the same system, and it being newer, I've only had trouble with it engaging once. I think the key is, always, and I mean ALWAYS, excersize the 4WD system every month or every other week.
But on my Tacoma, I have the shifter (on-the-fly) and personally, I like it better.
