For Sale Kingman, AZ 1976 IH Scout ii 350 swapped
Maryland, USA
$13000 or trade for solid front axle Toyotas, Land cruisers, hilux/pickups, fj40, fj60, 89 pickup or older if its been SAS
My Dad and I did a full GM drive train swap with a Chevy 350, SM465 manual trans, NP205 transfer case, Dana 44 front end, and Chevy 12 bolt rear end.
Details:
The grill is off a 73’
I did all the paint on the exterior and hard top, interior was stripped and bed-lined.
Hard top sliding windows were replaced in 2016
Original seats front and rear, rear is in good shape, little tearing. Fronts are rough.
I have a 12” sub bolted in the cargo area and an amp located on the passenger kick panel.
Comes with factory AC component that I have but never installed.
The previous owner cut a huge gouge in the passenger side wall of the cargo area, I made it into a small cubby with plans to put a net across it.
The truck runs great and 4wd works perfect. A few pumps and its turn key.
New exhaust built in 2016 which sounds great
4” spring over axle lift on 33”s
Has a few rust spots on the p/s rear quarter panel and corner piece and the hood, all quite small
Rockers are perfect
I started building a custom top to the factory center console. I still have the factory lid that it came with.
Frame is in good shape, surface rust only
Has mirrors, not installed
Has dashpad, 99% good
Needs:
Rear shocks
New wiring harness (the factory harness is still in, but nothing is connected under the dash, should still be useable, just old wiring)
Head light bezels
New weatherstripping
Shift boots installed/ needed for tcase
Running lights (have but not intstalled)
