"King pin" is one of the names used to describe the rotational point on a steering axle. Also referred to as "trunions". In the case of the 80 the term "knuckle bearings" is also used.
Old time solid beam axle spindles pivoted on "king pins" which were macinined "dowels" that were pressed into holes on the end of the axle beam and the spindles pivoted on the pins. The spindles were usually bushed with bronze inserts.
