I looked around on the various FJC forums and found several threads that talked about the programming instructions, but none actually had them. At most they pointed you to a website that "had" the instructions, or to downloading the entire Service Manual in two separate RAR files or a single ISO through a torrent feed.
I recently picked up a remote off eBay, and I just reprogrammed it to my FJ. Here are the double secret instructions (as listed in the Service Manual).
REGISTER RECOGNITION CODE MANUAL OPERATION
(a) Check that the following conditions are met
(c) Perform the following operations within 40 seconds
Response to mode selection (Power door lock operation):
[Add Mode]: LOCK-UNLOCK operation - Once
[Rewrite Mode]: LOCK-UNLOCK operation - Twice
[Confirmation Mode]: LOCK-UNLOCK operation: The number of registered codes (1 - 5 times)
[Prohibition Mode]: LOCK-UNLOCK operation - 5 times
HINT:
(i) If any of the following conditions are met, the Registration Mode will end:
- No key is in the ignition key cylinder.
- Only driver side door is open
- Close and open the driver side door twice.
- Insert the key into the ignition key cylinder, then remove it.
- Insert the key into the ignition key cylinder, and close all doors.
- Turn the ignition switch from LOCK to ON and back to LOCK 1 to 5 times at approximately 1 second intervals to select a mode (see table below).
I'll try to reproduce the table the best I can.
Number of ON-LOCK operations of ignition switch:
[Add Mode]: ON-LOCK operation - Once (use this to add a new remote)
[Rewrite Mode]: ON-LOCK operation - Twice (use this mode for completely rewriting all registration codes (e.g. you lost a FOB))
[Confirmation Mode]: ON-LOCK operation - 3 times (use this to confirm the number remotes currently configured to your FJ)
[Prohibition Mode]: ON-LOCK operation - 5 times (I'm not sure what this mode does)
HINT:
If the number of ignition switch ON-LOCK operations is 0, 4, 6, or more, there will be no response (power DOOR LOCK and UNLOCK operation) to show which mode has been selected. - Remove the key from the ignition key cylinder.
HINT:
- In Confirmation Mode, LOCK-UNLOCK operation will occur once for each recognition code that has been registered. For example, if 2 recognition codes have been registered, the LOCK-UNLOCK operation will occur twice.
- In Confirmation Mode, if no recognition codes have been registered, LOCK-UNLOCK operation will occur 11 times.
- If Confirmation Mode or Prohibition Mode is selected, the operation ends after the response to the selected mode is completed.
- Within 40 seconds of Add Mode or Rewrite Mode being selected, press the LOCK and UNLOCK switches on the transmitter (keyless remote) switch simultaneously fo 1.0 to 1.5 seconds. Within 3 seconds of moving your fingers away from the switches, press either switch of the transmitter for more than 1.0 second.
- Within 3 seconds of the transmitter switch being released, the LOCK-UNLOCK operation will be automatically performed once if the registration of the recognition code is correctly completed. (if not wash and repeat)
HINT: If the LOCK-UNLOCK operation is performed twice, the registration of the recognition code has failed, so perform the registration procedure from the beginning once again (bummer).
- The key is inserted into the ignition key cylinder.
- Any doors are opened.
- 40 seconds or more elapse after code registration.
