Hey everyone, I have a 2006 LC - I have one master key that came with my truck. I recently purchased a eBay key that was specific to my truck. Link is below...Now I have followed the instructions on TLCFAQ . com and I have the remote portion programmed, which will unlock and lock the doors. I just can't seem to get the immobilizer portion to work. I followed the steps several times, but the security light keeps blinking.
It states on that page that if it doesn't work that perhaps I already have 5 keys in the ECU, so I even tried to the method to delete them all except for the one master I have.
Can someone confirm that there are no tricks here I am missing? Thanks!!!!!!!!!!!!!
Program a New Key (2003+):
- Simultaneously depress and release brake and accelerator pedals 1 time.
- Insert your existing master key into the ignition. Do Not Turn!
- Within 15 seconds depress and release accelerator pedal 5 times.
- Within 20 seconds open and close the “driver side” door 6 times and remove key.
- Within 10 seconds insert new key into ignition.
- Turn the ignition cylinder ON and leave on for two minutes.
- Turn ignition cylinder OFF and remove new key
- Open and close the “driver side” door 1 time.
- After 60 seconds new key is registered and Security light goes off.
- Depress and release brake pedal 1 time to terminate programming.
- Insert new key and observe security light goes out.
- Start you Land Cruiser to confirm operation.
New Replacement Keyless Entry Car Remote Key Fob For Toyota Landcruiser 67 Chip
