Key Code Question
Mesa, AZ
Does anyone know if I have the original key code can a US dealer cut a key for a Euro Market 80 series? My truck is originally a Euro market 80 but is registered in the US and here in the US but my keys are all starting to get pretty worn. Trollhole is putting a new motor in it now but when I get it back I would like to get some new keys made.
I recently had 5 keys cut for my 94 without a problem. It was a US market model, but my preferred Toyota dealer in South Carolina charged $10 to look up the key code and then cut the keys for $4 each. To completely rekey the vehicle was close to $500 with all new locks (doors, hatch, glovebox, and ignition). New keys made a world of difference with the crabby hatch and sticky ignition.
If the vehicle is equipped with edge-cut keys like the US market Land Cruiser you can remove the key cylinder from the right front door and retrieve the key code stamped on the side of the cylinder barrel. Most Toyota dealers have key-cutting equipment and they can cut a key from the code. Take the cylinder in with you to test operation. If the key is an internal cut like an LX450 you will need to take the cylinder to a Lexus dealer and see if they are able to cut it.
Dan thanks for the reply I actually have the tiny tag with the key code that came with the original keys just wasn't sure if the database was worldwide I'll head over to the dealer and see what happens once I get thetruck back.
I'm not aware of differences in key codes between markets. You should be ok. Give them the code, have 1 cut, check it, then do the others.
Codes are universal. If the tag is original and the key cylinders have not been changed you are good-to-go.
