Key buzzer ---- I might have to kill myself
Arizona
Buzzes when the key is in the ignition. Does anyone know where the relay/whatever that is located? Or any other means of turning off that awful buzz?
The resource section may have a manual or electrical diagram to help you. I believe there is a small switch in the steering column activated by your key when inserted. Try wiggling the key.
That is the seatbelt warning relay. It will buzz with the key in the ignition, the driver's door open, and driver's seatbelt unfastened.
The relay is located in the driver's kick panel above the relay block.
Anyone got a pic?
