Kenwood Head Unit
Corvallis, OR
I was looking at this head unit to install in my 92 as a replacement for the craptastic head unit that's in there now, but I'm concerned about 2 things. The brightness and color, and it's size. Basically, I'm not too hot on the idea of changing out the head unit in the first place simply because of looks, but with all the features on this one, it's worth it. Anyway, I want it to match all the dashboard lights and everything almost as if it's stock, and I know I can change the color of the LCD to green to match the rest of the lights, but brightness and dimming could be a problem because when you switch the parking or headlights on, with the stock HU, the light dims to create a better "driving environment" if you will, and I'm not sure if I can dim this head unit. I also have seen so many people with aftermarket head units sticking out or not fitting right in the dashboard, so I want to make sure this doesn't happen and if it does, I want it to be fixable. Here's the head unit: Kenwood eXcelon DPX792BH 2-DIN CD Receiver with Built-in Bluetooth and HD Radio If anyone has any feedback, personal experience, or advice to share with me, it'd be greatly appreciated!
It should have a night mode tied into the headlight switch via the harness. I've installed a number of head units going back 15+ years and never run into one that didn't dim with the headlights, so you should be alright.
When I installed my Kenwood DDX393 there was a wire (orange I think) on the headunit harness for brightness. There was also a corresponding wire in the factory harness, but no wire in the Metra adapter harness. I was able to adjust the colour of the backlighting to match that of the rest of the HVAC cluster, but it took a while to figure out. Link to my install below.
Kenwood DDX393 - Installation Help for noob
I just installed this exact unit in mine last week. I was worried about the same issues.
Color is great, infinitely adjustable, just have to adjust until it's what you like.
Dimming- I didn't hook up the auto dim lead, as I drive with my lights on always, and I wanted it bright as possible in daylight. This unit has a feature that you can set it to dim automatically at a set time of day, which is what I did. If you want to at night, you can also turn the display off with one push of a button, and as soon as you make an adjustment (volume or any button) the display comes on for about 10 seconds and then shuts back off.
Fit- I think it fits great. I will take a picture later and post it.
Overall I'm very happy with it so far. Pairs up very easy and quick with my Galaxy S5 and sounds great.
I bought similar version but way cheaper. All the features are great, there's dimming capability and fits perfect in dash. The only drawback to any of these head units is visibility during the day. Glare and bright light make the display hard to read. Other than that, momey well spent.
Biggest difference between these two is the quality of the amplifier. Here's a pic of mine installed
Biggest difference between these two is the quality of the amplifier. Here's a pic of mine installedView attachment 1334001 View attachment 1334002
Thank you, exactly the answer I was looking for! :)
