keeping a 80 cool
Virginia city NV.
OK dose any one know how many C.F.M. it takes to keep these pigs cool in stock form. this fan clutch thing is driving me crazy i replace it with genuine Toyota parts and a year down the road I'm looking at it again even used the blue one last time. thinking of going electric. mostly the wife drives her in winter and i don't think she knows what the gages are for so it has to be reliable.
thanks Richard
Richard,
You haven't given us much to work on so I will make one comment:
The stock cooling system in a US spec 80-Series with the 1FZ-FE engine is more than adequate to keep the engine properly cooled in extreme conditions (e.g. 120* desert heat for extended operating periods.)
You must look at the cooling system, not a single component like the fan or the fan clutch. Everything must be operating at 100% efficiency:
* Radiator
* Coolant
* Water pump
* Thermostat
* Hoses
* Radiator cap
* Fan and fan shroud
* Fan clutch
* Fan belts
* Engine block (HG, water passages, etc.)
If you've added things that soak heat like a S/C or block air-flow like driving lights or a 2nd battery then you might benefit by more air moving capacity (what you referred to as CFM) when the vehicle is stationary or moving slowly through traffic. Those are the typical times that a secondary electric fan might help, especially with A/C cooling.
The easiest way to accomplish more air movement is to increase the viscosity of the fluid in the fan clutch. (i.e. 10,000 cst if you are in Phoenix)
-B-
this is to deal with the simple unpredictable fan clutch failer that happens every year like clock work. no lights stock bumper. the fan clutch only works at slow speeds like on the trail or in traffic once you get up to speed the clutch is defeated and air come through the radiator by wind speed force. oranges to oranges if i remove the OEM fan clutch how many CFM do i have to achieve minim 120f not moving to keep this pig cool.
There might be a simple xxx CFM answer to your question but I doubt it.
This thread was in response to a similar request a few months ago:
https://forum.ih8mud.com/80-series-tech/230377-factory-fan-cfm-range.html#post3471736
This is the only relevant thread that I can recall that might help with your question.
https://forum.ih8mud.com/80-series-tech/56797-fan-test-long-post-many-pics.html
The above threads were found by doing an Advanced SEARCH using the keywords=fan CFM, 80-Section, all authors.
Good Luck!
-B-
If your goal is to have a good working fan system capable of moving enough air for 120F weather, simply changing the fluid in the clutch to 10K+ will get the job done. A good thread on doing it;
https://forum.ih8mud.com/79-95-toyota-truck-tech/167678-fan-clutch-service.html
More info would be helpful, where is the rig operated, what mods, how is it wheeled, etc? Given the constraints of the electrical system and coolers thickness, I doubt that you will find an electric setup that will pull near the air that a properly setup stock clutch will. The stock system is extremely reliable, as long as the belt is on and the fluid is good, it makes good airflow.
well there is always my $0 / 1 minute mod for increased cooling... :D
Well, that's more or less true but we still don't know what your problem is. When does it overheat? Traffic or highway?.
I can't imagine a new fan clutch every year as these things usually work fine for a decade...
Just try to keep an open mind and not a 'I want those electric fans' approach and we might be of some help. Of course anybody could tell you to get $500 and buy those fans but they might not solve your problem...
Maybe a bad thermostat or clogged radiator due to coolant sludge? Just get us more info.
OK over heated coming off the trail yesterday, it's in the red trued it off got out and spun the blade by hand around and around it went, it then cooled off started to climed in town for air up. was fine out on the trail i have noticed a slite needle move up but know ware near the red. just replaced the radiator due to plastic tank exploding replaced all fluids radiator is now an all metal unit. 95fjz80 3in lift electric lockers 34in tiers daily driver and wheeling on the week ends back to work day care on Monday long trips with the kid and so on.
on another note also had this problem with my mine 85 4x4 EFI 22RE went through 4 clutches OEM before the one in there right now that has lasted 8 years the 76fj40 has a direct drive unite so know worries there.
Upgrade the clutch fluid. The stock stuff is too light and goes bad quickly in desert conditions, the thicker stuff transfers much more torque to the fan and lasts much longer. Most of the time the clutch is like new, only the fluid goes bad. The 10K fluid in mine is ~3 yrs old and still works like new, has been wheeled in 115F+ with zero issue.
Kevin,
Can this fluid be added to the non blue fan clutch? I'm still running the original '93 on mine and I was thinking of putting the thicker fluid in the 97's blue clutch this spring and doing them both at the same time along with my bro in law's original 93 too. Does this basically make the older ones as good as the blue one?
Thanks, DougM
i do believe i am going to go this rout. ware do i get said fluid seeing, as a 6000cfm radiator costs 500$. what is the fluid called? what is it for? how much should it cost?
but we still need to nail down how many CFM an 80 needs for posterity you know.
Kevin,
Thanks, DougM
IMHO the original Eaton clutches aren't made as well as the Asian units, that said they have proven to last. I have upgraded the fluid in several with good results, all are still working, not bad for 12+ year old units.:hillbilly:
There is a picture of the hobby store stuff in the link above. You have two choices; it's ~$15 per 18ml from Toyota, need 3, or the hobby store stuff is ~$10 a bottle, all that I have used it's enough to do a couple of clutches. The hobby store fluid is used in the differentials of high end R/C cars, so is available from stores that sell that type of rigs.
How much CFM the stock fan moves is not as simple as it looks. It's restricted by two and a half, relatively thick coolers, so even if you calculated the the max flow, what is the restriction factor? Most of the after market fans are rated free air, when restricted by cooler(s) that number would drop to a fraction of advertised.
The design of the coolers is different on electric fan rigs, the coolers are thinner, with a much larger surface area, making them much less restrictive to allow the less powerful electric fans to work. The stock fan is pretty stout, would pull a bunch of free air, more importantly is powerful, capable of moving a bunch of flow through a relatively restrictive/thick cooler stack.
The other advantage of the hobby fluid is that it available in thicker viscosity. I get 10,000 and 30,000, this allows for mixing, tuning for best performance in your conditions. For our conditions (AZ desert) and late type blue hub clutches, 13K-14K fluid has been working well.
This is not totally correct. An 80 is about as aerodynamic as a brick. More air will flow around the front than through the radiator at highway speed. The fan creates negative pressure which causes more air to flow through the radiator. When my fan clutch failed she would run hot on the highway even at moderate ambient temps.
