keep blowin fuse
Oakland, OR.
the horn fuse keeps blowing out soon as i try to put it in on my 71 fj 40. this started hapening when trying to fix the blinkers( they still don't work either). i haven't cut or changed any wiring exept put a flasher for LED tail lights in.
checked grounds, disconected every thing on that circut to narow it down, sprayed kleener and blew out the emergency flasher switch also. keep blowin fuse.
all the wiring is in real good shape.
and i have done some serches but no luck.
sorry for another newbeee electrical quistion but i'm really stuck.
Ortayga;
I'm assuming that the STOP lite fuse is blowing. Early '70's FJ-40's had horn relays and they were wired into the STOP lite fuse. Remove the bulbs from the brake lite pods and re-install a new fuse. Sometimes the bulb filament will blow and short to ground; which continuously blows the STOP fuse.
IIRC no fuel guage and no brake light if that fuse is blown.
the PO pute LED brake lites on it. i have tried unpluging them to.
ya the brake lights don't work any more, and the fuel gage didn't work when i got it.
i was messing withe the turn sig switch and got the turn sigs to work but slowly got irregular and stoped, then would work some more.
i found one on specter, but don't want to spend the money if that ain't the prob. i guess that the learning curve can get spendy sometimes..
can the fuse blowin for the horn circute (the second fuse down from the top) and the blinker prob be tied to gether or em i all screwed up?
I don't mean to hijack the thread here, but I am having the same issues. However, it is my fuel/temp guages that keep going out. I think its the 3 or 4th fuse down in the block (12/76 fj40).
I have traced every wire known to man under the dash - and around the engine bay, I can't find anything or any short. I am at a total loss, and its killin me becuase these are important guages!
I have not tried the horn, to see if it's in the same circuit..
later,
ragman
dmaddox;
One really needs FSM 98154 to shoot some of these problems.
The 5th fuse down should be the HEATER fuse. It controls the combination meter (Oil, Water, Fuel) and heater, backup lite, transfer switch et al.
The earliest schematic I have is for 1975. A Haynes book is helpful for 1975 and up. Prior to that year, the drawing are crap for trouble shooting.
I would check the back up lites for a shorted bulb.
i just recently got my 40 and the the only gage that works is the amp meter, and all the wires i have traced look perfect.
i don't know if i'm starting in the wright place but since i'm a electrical dummy i don't know any better
so any thing you figure out on your gages let me know and vise versa.
thanks
does any one know how much the FSM book cost? i tried to call and they were closed.
nevermind, i figured it outt
thanks
You've disconnected the horn? The horn switch works by providing the earth, so the problem is somewhere between the fuse and the horn (if it's the horn part that's faulty).
Try disconnecting the wires coming out of the fuse block.
Pick the one fed by the faulty fuse - if you get a circuit to earth, then there is either a fault (melted wire, chaffed wire) or there is still something conencted to it.
Wiring faults can take a long time to find - just systemattically go through everything slowly - I ended up completely rewiring my cruiser in an attempt to fix a problem. (now fixed, still dont know what it was - but now I have new wires everywhere :) )
And dont bypass the fuse - its there for a reason!
If it is blowing fuses repeatedly, they either there are too many devices on the circuit (like a 500 watt audio amplifier) that are drawing more current that it is rated for OR there is a short to ground somewhere. Bad gounds or bad connections aren't the problem, it is an inapropriate connection or too many connections.
Disconnect ALL the devices (lights, horn relay, etc) on circuit that are shown in the schematic diagram. If it is still blowing a fuse, a wire is shorted to ground. Either trace the wire all the say through its harness until its next connection or run a new wire and leave the old one disconnected.
If the fuse doesn't blow after disconnecting everything, then the wire is not shorted. Start connecting devices one by one until you find the one that blows the fuse. The one that blows the fuse is shorted and needs to be replaced.
on the wiring diagram it shows a stop light switch with 2 wires. is that supost to be the switch for the brake pedel?
my brake switch has 4 or 5 wires.
or is it just because the diagram sucks
