Recently I had a shop install the OEM spacers for the front struts on my 2011 200series. Then I've been noticing a lean which is 1inch lower on the front driver than on the front passenger. I've done all the KDSS lean fixes with no improvement (unless I'm doing it wrong). So I took a closer look at the struts and notice a difference in height..the front passenger (higher side) strut top hat seems to sit about 1 or 2 inches above the UCA and the front driver (lower side) strut top hat seems to sit about level or a few millimeters below the UCA. could this be installation problem vs kdss? Or does the LC200 Really sit lower on the driver side normally. In the picture below you can clearly see the top hats are different in heights which I'm assuming is causing the lean. Can anyone verify that is the correct positioning of the struts?
