Or here,, some easy info you might want to print out for reference while working on the 416.. graqbbed it off m416 msngroup a while back to use myself..
Wheel Bearings (4 per trailer):
Federal Mogul Set A-35, which consists of:
Bearing: LM501349
Race: LM501310
Grease Seals (2 per trailer):
Federal-Mogul 472018
*note, for some reason these seals are rather expensive.....~$10 each, but
they are much cheaper than M151 seals at 17 each. The F-M seals do not
have the lip that prevents the seal from going too deep in the hub, but driving
it in with a block of wood makes them seat just fine.
IMPORTANT:
The Portrayal Press reprint of the 1970 Edition of TM 9-2320-251-14 has a big error in the sequence of assembly for the hubs on pp24-25.
The correct sequence (from the inside out) is as follows:
1. Grease seal
2. bearing
3. race
4. hub
5. race
6. bearing
7. tabbed washer
8. spindle nut
9. lock washer
10. lock nut
Note: you'll need a 2 1/16 hub bearing locknut socket (for early jeep, Scout,
and Land Rover) to get to the bearings. Price is generally about 10-15 bucks
and is available from JC Whitney or any GOOD jeep parts dealer that
understands that jeeps were made before the CJ-7 introduction in 1976.
Shock Absorbers (2 per trailer):
NAPA 94038
*this is for a mid 1970's CJ-5 with a 4cyl engine
Springs:
1950's vintage CJ3A/CJ3B FRONT leaf springs (36.25x1.75 inch leaf springs)
Spring Eye Bushings:
1950's CJ3A/B Front leaf bushings
Shackles:
1950's vintage CJ3A/CJ3B shackles.
Note there is a right and a left threaded shackle. You'll need one of each.
Available from JC Whitney or any jeep parts specialist. These are commonly
called "c-shackles"
U-bolts:
Again, 1950's CJ3A/B U-bolts for a Dana 25 axle. You want the "skinny" u-bolt
as there is also a wide u-bolt to clear the pumpkin on a D25. With nuts, they
run about 3.60 each from
Walcks 4WD - Willys Jeep Parts - 10% Off Thru December - Brakes, Bumpers, Tires, & Wiring Harnesses for CJ2A, MB, & More
