Just need a few specs
I took the carb off today so i can get it rebuilt and while i was at it took the valve cover off so i could polish it up while im going through downtime since i saw someone on here a while back done an awesome job at it. It needs a gasket anyhow. Anyways just wondering what the valves are set at and how tight to draw the valve cover down to. Also i noticed today on the emissions set up that check valve is burnt off from where it screws onto the big line of things that looks like injectors. Lol im still so new to a gas engine especially one with all these emissions on it. Im guessing that i will have to buy another one of these correct? Spector has used ones for 30 something bucks which isnt so bad. Just curious to how all these emissions work really. The pump im sure hasnt worked in a long time anyhow because its locked up and has no belt on it. Thanks again guys im getting one step closer to getting this baby running like a new one.
Also one more thing, i found another broken vacuum line. Everytime i find one of these buggers its really makes me jump up and down cuz im no its one more thing fixed. SOR says its a gas filter...........dont think thats right but it screws into the intake right in front of the carb. Cool beans im loving this toy so much.
Howdy! Are you going to make this rig smog legal? If so, then yes, you need to replace the one way check valve in the A.I.R. System. Should be able to match up a generic one at a good parts store for cheap. If you don't need smog, then just pull out the "injector" things and put in plugs. There is a nipple down inside the manifold under the "injectors". Tap an old drill bit into them and grab onto it with vice grips and it will come right out. Makes the exhaust flow better. SAE gas pipe plugs will fit right in to holes. Use some gasket sealer on them to seal it up. John
Sweet
Im not worried about smog. For the time being its gonna be a farm vehicle. Thats all there is to it? My question though is this fool proof. Like can i drop something down into a cylinder while pulling the plugs out or is it just as easy as you said? What else is their to desmogging?
Howdy! Everything you are removing it too large to fall in. No risk. The A.I.R. System is only one part of the smog equipment. There is also the E.G.R. as well as spark timing control. John
Valve clearances are listed in the haynes manual, or FSM. I believe its .08 and .14 not sure which is intake and which is exhaust off the top of my head though.
Howdy! Intake is 0.08" and exhaust is 0.14" set with the engine at normal operating temperature. John
I took the rail off this morning and then unscrewed the next part thats kinda like an injector and then put a screw driver into the holes to feel for the part you pull out. I never could feel anything and the screwdriver bottomed out. Do they burn out over time or could they of been pulled a while back, which i doubt because i know whose had this since 82 and its a 78. If they're in there what does it hurt to leave them in?
Howdy! If you used a really small screwdriver, it may have gone out thru the tip. Try a drill bit that is just a little smaller than the threads on the "injector" part. The nozzles look like the tip on a blow torch. It's possible they have been removed or they self destructed. Even if you do leave them in, it is a very minor difference in performance. It was a popular "cheat" back when the states did a visual, but not a sniffer test. It left the system intack and operational, it just was not very effective at reducing smog with the tips gone. John
Gotcha, cool beans i'll go try it again maybe or probably tomorrow. Guess that means im really in the Xmas spirit lol. Thanks guys
yeah i forgot about that. If no one responds i'll just draw it down slowly. It wasnt very tight i do know that.
