- Thread starter
- #21
Sounds like time for a lift...with the coilovers you have on the front, and the ARB, you are probably close to stock. A couple of inches would have probably suited those trails a bit better.
Exactly!!
I am going to put the 440 Constant .75 lift OME springs on the rear which SHOULD give me about 1 1/2 " lift ...from what we have found after you put them on. Then have radflo put on the back, which should not matter in the lift situation.
Then I am going to have my guy raise the coil overs on the front till they are 1/2 inch from max. Then see how she drives.
If my numbers are correct it should give me 2" in the rear and about 1" to 1 1/4 " in front.
It won't be any better with the OME fronts because I am still starting at a NEGATIVE 1" to 1 1/4" deficit from the arb bumper.
What I don't understand is that they list them as separate springs and shocks, not coilovers.
The only options would be if someone created a lift with spacers...but who knows how stable that would make it being that high up.
