Just Bought a 96
I pulled the trigger on a 96 with 190k miles, paid $3800 (does have lockers). Will need tires soon and the LR window does not work. Clean exterior/interior. However, I had not heard about the head gasket issue until I came here. I've not had any problems in the week since I've owned it, but with that many miles should I start a fund?
I read the HG threads, but I didn't get a sense for how fast it happens. I owned an Acura with a gasket leak that was very tricky to pin down. Basically, will it be the same with the cruiser or will I know rather soon? I was hoping to get another 4-5 years with light driving - does that sound do-able?
Great site and thanks for any help...
Added my inspection report - if anyone sees any signs of doom on the horizon please let me know.
_____________________________________
1996 Toyota Land Cruiser 4.5 L 4476 CC L6 1FZFE DOHC
USED CAR INSPECTION
-------- CHECK FOLLOWING -------------- .
#1 ( OK ) engine condition
#2 compression 1_175_ 2_175_ 3_175_ 4_165_ 5_175_ 6_175_ 7_N/A_ 8_N/A_
#3 ( FAIR ) engine tune
#4 ( OK ) drive axles, cv joints:
#5 ( OK ) front suspension:
#6 ( OK ) rear suspension:
#7 ( OK ) transmission condition:
#8 ( **** ) tires:
#9 ( **** ) brakes: 40% F 5% R
#10 ( OK ) lights:
#11 ( OK ) belts and hoses:
#12 ( **** ) antifreeze:
#13 ( OK ) cooling system condition:
#14 ( OK ) battery condition
#15 ( OK ) charge system:
#16 ( **** ) windshield and wipers: REC: BLADES (CHATTER)
#17 ( OK ) heater? air conditioning:
#18 ( OK ) exhaust system:
FRONT TIRES HAVE OUTSIDE EDGE WEAR, REC: TIRES
FRONT BRAKE LINING GOOD 40% REARS AT 5%, REC: REAR BRAKES W/ROTORS
R/F WHEEL BEARING HAS PLAY, REC: BEARING PACK
COOLANT NEEDS CHANGED, OVER SPEC ON TEST
ENGINE OIL LEAKS AT VALVE COVER AND REAR MAIN AREA
P/S PUMP SHOWS SIGNS OF LEAKAGE
ENGINE LIGHT ON, HAS CODE FOR EGR FLOW. SUSPECT PASSAGES PLUGGED OR SENSOR ISSUE
Welcome to MUD
First off, do a search through the FAQ section and look into performing so baselining activities.
Stick with factory parts if possible, contact CDan at American Toyota for all you part needs, plus MUD members get a nice discount. He is THE MAN!
I would do the front and rear brakes at the same time if possible, pads and rotors. Just to have everything 100%.
Most of the items you have listed are fairly managable for most. Just make sure you have a nice selection of tools.
Order a FSM (Factory Service Manual) as soon as possible, this will make your life much easier.
Use search, it will answer so many questions.
Good luck and post some pics when you get a chance.
Thanks for the info. I just saw the gasket threads and was worried that I might have over looked something (would be my luck). I've heard these things eat up pads like crazy too.
I'll spend some time in the stickies for a bit...thanks. :beer:
Wow prices have really dropped on these. You basically paid half what I paid for a 94 with 185k miles two years ago. Welcome and let's see some pics!
Congrats and welcome, Yes lets see pics!
Geez that's a good price, it does sound like it needs a bit of work though. I paid $4500 for my 96 with 165K on it and a bashed in door, cracked windshield, broken antenna and blown PS pump, now I don't feel like I got such a great deal. :doh:
congrats on a nice cheap find :flipoff2: i wouldnt sweat the HG. if it goes..it goes is what i say. hopefully if it does...you wont be on some thousand mile trek in the middle of nowhere. check the dipstick and hopefully it wont be creamy. watch your coolant levels, and maybe have a sniff at your tailpipe for signs of coolant. otherwise, baseline it, change your coolant, either repack your front bearings, or do full front axle service, and you're good to go. all of which are explicitly detailed in the FAQ. get parts from cruiserdan as mentioned...it'll make you smater than staying at a holiday inn.
amazing price!
Less than a year ago, i traded a 2004 mustang convertable for my 96 with 145k and no lockers...
have fun with it!!!
Welcome. Nice buy. If that's all mine's worth now, I'm gonna own it forever! Hell, I may even buy another.
