Just another "recommend me a suspension kit" post
Since the spring rate on the 675Vs is 157-230 lbs/in, it seems like the first 157 lbs will lower the rear coils 1”. Or something like that since I don’t know exactly at what weight or when the stiffer spring rate kicks in.
And when others put in heavy springs in the rear, it would be good to know your spring rate in terms of lbs/in
@DRANGED if you gonna put 1000# in the rear and then DD on the light side, that’s a tough load to manage!
You need to move up the heavy progressive springs and might need the supplemental air bags to insert in the rear coils to hold them up.
From the 4R web site:
C59-675V - Variable rate comfort option, stock rear weight, 2.5" lift. 470/470mm, 16mm wire, 157-230LB variable
C59-677V - Variable rate comfort option, 400+LB heavy rear load weight, 2.5-3" lift. 500/500mm, 16mm wire, 157-230LB variable
C59-701V - Variable rate, 600-700 LB heavy rear load weight, 3" lift, long travel. 500/500mm, 17mm wire, 210-245LB variable. Designed for those with heavy full rear bumper, tire carrier, roof rack, RTT, drawers, and fridge. Rides very well with all that weight, as well as when loaded even further.
C59-749V - Variable Rate, 750-900 LB super heavyconstant rear load, 3" lift, long travel. 520/520mm free height, 18mm wire, 198-300LB variable rate, usually around 270LB at loaded height
@HomersCanyonero
Yeah, that's exactly my the challenge, and why leaving stock is so hard... Auto-levelling plus the rear 1.6" boost in HI...until the bags fail.
I'm thinking a med spring should be fineokay, maybe stiff DD and maybe a little sag on the big trip. The 1000# trips are maybe once a year, but I always overpack water. Thinking a medium spring and adjusting rebound for DD, vs. laden... All these perspectives are good data for the MRA!
