To recap, I had no AC cooling a few weeks ago in my 96 FZJ80, so added the combo R134a/UV dye/oil/sealant from the blue do-it-yourself kit/can from Advance auto, then I tightened but did not reseat all three schrader valves. Over the last few days I noticed progressively less cooling then none at all. When I took off the Low port cap this time I noticed there was the yellow UV dye under the cap and around the inside of the port, but none outside of the port. I had cleaned it up real good before I put the cap on a few weeks ago, so figure at least some of the leak was from the schrader valve.
So this time I loosened the Low port schrader valve until I got some pressure/leakage coming out at me, then quickly tightened it back up in hopes that it may reseat the valve, and then recharged with one can (12oz) of R134a only. The pressure only got maybe to 30 at 1500rpms (from the cheapo dial gauge that comes with the kit). Cooling very well again now. I figure I have at least one leak at the Low schrader valve, but could not see any other obviously leaks on the compressor or the hoses attached to the compressor. Previously I think someone suggested that you may be able to get away with not pulling a vacuum if you were quick with replacing the schrader valve. I'm guessing I would not be quick enough.
Should I just go ahead and have someone pull a vacuum anyways as the system has leaked down a couple of times and now has a mix of old and new oils, old and new coolant, maybe some atmospheric moisture, etc?
When the AC tech does the service where they pull a vacuum and recharge, does that suck out all the old oil and coolant, or just the coolant, or do you have to open the system to completely drain it?
