You're right about the pumping thing, but it is dependant upon the fluid volume of the calipers you choose. I tried to make that clear. Having not considered this before hand, I used calipers that were used on the front of 1970s Chevy 1/2 ton four wheel drive trucks. These take huge amounts of fluid, and yes, pedal pumping was pretty much necessary. That's all fixed now. It would have been easier to find a caliper better suited for this with a lower fluid volume requirement, but I was already past that point. So, the moral to the story is get a smaller caliper to begin with and you won't have to jump through all the hoops that I did. And as far a line locks go, that's a fine way to hold it in the driveway, but in the event of a brake system failure, you would be screwed. That's why I would rather go for an independant system, although a line lock is better than what I currently have which is nothing at all.
The Monte Carlo calipers that are used in all the kits and the vast majority of the home grown conversions are already too powerful for the tail end. From a design view, the whole conversion is a bit of a kludge... but it works nicely when all is done. I would never use a larger caliper than the Monto carlo units. Smaller would be better if you wind up building your own brackets anyway.
As to the arguement that if your brakes fail, then you have no emergency brake..... I see this brought up a lot... but let's take a closer look.
1) how many here have properly functioning OEM parking brakes? My money says that well over half do not... so a line lock that *might* fail doe to highly unusual occurances is still an improvement over non functioning OEM parking brakes.
2) when the OEM parking brake IS working..... how many hear really want to depend on it as an EMERGENCY brake? To be blunt..... what a joke... it will barely hold a rig stationary, much less slow it from speed.
3) your front and rear braking systems share only the reservoir. in the event of a rear brake failure, the partially function front brakes are still far superior to the OEM parking brake in any case... Sure if you are foolish enough to try and continue down the road with a ruptured line, you will run the reservoir dray and loose the other system too. But if you are that foolish....
4) Look at what it takes to disable your rear hydraulic braking system... How often have you seen that happen? Look at what it takes to disable your OEM parking brake... and how often that happens.
Now tell me..... Are you really worried about a line lock being less capable or less safe than the OEM parking brake?
I am not
Hold in the driveway?
I use mine for holding my rig in place with a PTO dragging other rigs out of mud holes and 40x18 inch boggers grabbing traction and trying to overpower the brakes. on tundra or on pavement.... the tires slide over the ground before the tires turn. Try that with an OEM parking brake
I also keep the tranny brake functional on my 40's... No reason not to. If You can figure out a clean way to route the cable, then the Eldorado calipers are nice with the mechanical parking brake for use under a '6x series. But I would still use line locks if I really wanted to hold the rig in place.
Mark...
