where is the best place to get the rear disc conversion brackets for my 60?
OK. I got that answer already.
Now for my next question.
What all is involved in this swap? I'm coming to find its more involved than I thought.
Anyone have a link to a thread about this?
Is there a thread about rear disc swaps for 60s?
not e-brake . ?
Post pics of that, please. I'll eventually be in the same boat - needing a p-brake on the rear of an NP241. I recall reading that you made a SYE or that the t/c came that way?
Some bad info floating in this thread.
I have done more rear disc conversions than I can recall at the moment....
The GM calipers do NOT result in a soft pedal or one that need to be pumps. You do not need to replace your MC. The FJ60 brackets are available, at least as of the last time I checked. There is nothing complicated about the swap. You will loose your axle based parking brake. A line lock works great as a parking brake. You do need to used an adjustable proportioning vlve along with your OEM proportioning valve. You need to remove the residual valve from the rear circuit of your M/C. An inline 2 pound residual valve is a good thing to include.
Mark...
Mark...
