Build JDM 73
Quick trip down the highway from one end of town to the other, 2100rpm (ish) at 60mph (4.88 diff gears and an automatic trans) Boost/EGT doesn't seem to be affected by the GFB bleed valve very much Might throw the 14psi spring in the actuator instead. would like to try and climb a hill on the highway to see how bad it does.
I'm running those same tires with 17" 4Runner steelies (7"wide vs 7.5 on the FJ), with a 1" spacer. So far I have been very pleased with them. They are so much quieter on the road than my previous BFGs. They look good on your truck, and hope you are able to remedy the tri-pod situation soon. I don't have a tach and would be interested in your hwy RPM's when you get a chance.
@svsisu what turbo/wastegate setup do you have on your 1HZ? what are your EGT's like?
I drove it down the highway to the next town (20miles or so), slightly uphill the whole way and it was between 700-850 cruising at 55-60. going back the other way I was doing 63-65 with the temps in the 600's. I fiddled with the boost controller/bleed valve when I stopped to turn around and got the boost around 8psi but wasn't able to see much difference with just one drive.
I have a stock toyota CT26 turbo/wastegate from an HDT, boost is around 10 psi. I have not really had any issues with EGTs, 2.5" short, straight exhaust that exits just in front of right rear tire I feel helps. I have some notes on temps, but not with me just now. Mostly stay in 600-750 F range at 65 mph on flat terrain, 800-900 on moderate hills or strong head winds, and pulling up long hills at speed I've gotten up to 1200 F briefly once or twice, but they drop immediately with backing off on the throttle. I have an alarm set at 1100 F to be sure I'm alerted if not paying attention. Engine and EGTs most happy on interstate at 65-70 mph. I have a H55 5spd with 4:1 reduction gears in t-case, and 4.11 rear,;going over 70 for any length of time is pretty self defeating all the way around.
Where I have run into problems is with cooling temps after having the IP and injectors rebuilt. Before having those worked on temps were fine, would rise slightly in the mountains on long pulls, but come down very quickly. After rebuild, truck ran like a slow, tired dog in hills and coolant temps would shoot up rapidly on moderate to steep inclines. At sea level, and flat ground nothing apparent, but get up in the hills and I would really need to watch coolant temps, even on overpasses at certain elevations. I often travel for the coast (sea level) to Appalachian mountains (2500-3500 ft), which is mostly a long gradual grade to 1000' then the grades increase quickly. The worst temp problems along this route happen in the 300-700' range. I've come to find out that the shop that rebuilt my IP left out some components in the boost compensator and did not have the fueling set correctly. I have auber gauges and probes for EGT, coolant, and boost, and been happy with them so far. I'll send you PM with some more details.
As you've asked and has been covered in earlier posts you may want to revisit exhaust (make less restrictive), timing and fueling on IP and injectors (can't remember if these have been rebuilt or if you have a boost compensator?), ensure entire cooling system is in good working order. So many variables that are inter-related makes it hard to pin down. Fueling/timing and air to fuel ratio plays a very significant role in this. Sorry for your struggles.
Well, I got old thermostat out. For some reason my Google-Fu and parts number searching led me to believe a 2LT one was the same....drove 40 miles for one that was at a Napa...nope, not the same. So i ordered one and now I wait. The one I pulled out said 76* C (or 169* F i think) so.....
Well, i thought about it all evening and this morning so far and I think i will pull the trigger on an ebay aluminum one....but i hope the new thermostat will probably alleviate most of my issue.
Well, eBay radiator turned out to be a huge hassle. Got lost in transport and they refunded me. Bought a Terrain Tamer instead, PN 16400-17070TT along with their hose kit.
Install went pretty well, my OEM steel fan shroud had to have the holes slotted out to fit and some trimming along the top but almost a bolt in.
New thermostat and new red hub fan clutch and it should stay cool.
