JAOS Mudflaps 300 series/LX
Texas
Has anyone put JAOS mudflaps on there LX?
Wow! Only $99. I was expecting them to be $500 a piece since the fender flares are $6,000
The kit includes the mounting bracket i believe. Buy you still need to buy 2 pairs of large JAOS mudflaps. So least $300
Is there any company out there that makes integrated fender flares and integrated mudflaps that would also fit with the running boards? Need that lx450 classic look.
I've had these for several months but need to install it. How was the install?
The hardest part was definitely holding the phone steady for stupid Google Translate on the instructions lol. Once you do the first, it’s pretty quick for the rest. Trimming the guards to the pattern for the lx and drilling g the holes is the prep work. I used some thick shears but tin snips might do well too. Also recommend using brad point bits for all your drilling. Then no need to do a double drill a pilot and then upsize and your bit won’t wander. I’m pretty sure it’s too thick to use a wheel cutter. For actual install, 18v ratchet, wera joker, and a creeper made it pretty painless.
Anxiously waiting for pics! :)
Not op, and I got the guys who did my sliders to do the flaps so I don't know how they're installed, but:
Before the first trip:
After a few:
Only issue so far is I popped a screw out. But it probably was a skill issue.
Can we get more photos of the front flaps and what they look like in the wheel well (with the wheel fully locked)?
N, N, H1, H2. I’m gonna call it maybe 1 3/4” at the closest in each. Eyeballing it but doesn’t seem to change substantially. Now if I had already crammed 34-35’s in here then I’m sure every mm counts. Let me know if this is what you wanted.
  • Like
Reactions: eNx
Sweet thank you. I figure I'll probably still just rub on these with the 35s, but I could probably shape or trim these.
