SOLD Jackson, MS 80 Series Axles ARB Lockers w/4:88 Gears
Raymond, MS
Recent knuckle rebuild, stock shafts, front has not been running backing plates, and had a Marks 4wd ABS relocation kit so knuckles have freeze plugs where the abs sensor would go. Sold as pictured without front hubs. Rear is still under the truck but will be out next week is complete minus rotors, calipers, abs, brake lines and parking brake cables. ARB lockers and 4:88’s were installed by Slee. One thing worth mentioning is the rear may need o-rings replaced as the compressor would cycle frequently when locked. The solenoid for the rear was also sticking and not fully closing but want to be upfront that there may be an issue. Front holds and compressor does not cycle. Customer has decided to go with a set of OEM Locked axles. Compressor not included. Asking $3500obo.
More pictures will be posted of rear axle once it is out of the truck.
Rear axle is out now and ready for its new home.
  • Like
Reactions: dnp
