I let off the gas and coast around turns as well. I just didn't understand why people that had them with an auto trans said it was different.
It was cut out to fit the 4btDoes that picture show your steering brace removed completely?
They are no joke..Yep, looks like someone cut it out.
Neat to see some of the other Montrose trails are doable in a Cruiser - @cjmoon @tornadoalleycruiser and I tried to do Topless in August and turned around![]()
That's not great workmanship. You really need that brace in place. You should be able to drop it an inch on the passenger side and clear the pan fine. If not the engine is installed way too low.It was cut out to fit the 4bt
I will be exploring options for sure. I can’t speak to the swap craftsmanship as it was completed 10 years and 40k miles ago which shows it wasn’t a complete failure. I can speak to the fact that it was not built for how i am using it which is why I am finding the weak points. As this will be a continual build as new weak points are found I have no issues with the little things.That's not great workmanship. You really need that brace in place. You should be able to drop it an inch on the passenger side and clear the pan fine. If not the engine is installed way too low.
