I've got wobbles....sometimes.
Enola, PA.
I have a '97 FZJ, stock with 124K on the clock. I have new rotors and pads on my to do list because PO did pads only @ 100K....I don't know why. Several days ago while cruising down the highway the steering wheel started to shake. Speed didn't matter and the brake pedal was stiff and pulsing hard. I'm thinking warped rotor and/or sticking caliper but.....I pulled over, shut it off, restarted with no cool down time and it's smooth as silk. Same senareo two days later. Is something other than a sticky caliper going on here? The intermittant thing has me puzzled.
If the rotors were in spec, then there's no reason to change them. You are going with OEM parts, yes?
The pulsing thing has me thinking ABS. I'd pull the ABS sensors and make sure that there are not metal shavings stuck to them....if there is, then you need to do the front end job and find out why there are metal shavings stuck to 'em.
I'd get the tires balanced (just to knock that out). It's likely not a tire balance issue, but sometimes that can cause weird behaviour.
Also check all of your nuts and bolts. The nuts on your knuckles, calipers (the bottom one can back out and cause problems), and everything on your suspension and steering.
check your front wheel bearings. When they are loose they can sometimes behave like this.
x2 on loose wheel bearings.
-KK
Thanks for the feedback.
Yes to OEM, Cruiser Dan or Kurt.
My local inspection mechanic pointed out that that pads were new but the rotors were scored and had not been turned. They would probably not be in spec after turning, so I decided to drive it until they started squealing then replace the rotors and pads.
I've done several 40 front end jobs, never an 80....I'm off to FAQ.
Well, what was it?
