Good morning
Last month I realized my ebrake wasn't working and it was making noise. I disassembled it and fully removed the ebrake assembly because I needed to drive my car in the meantime while the parts came from Japan
Previous owner rigged something up and it obviously wasn't working. I ordered new bell cranks, springs, hardware, boots, brake shoes, everything except the adjuster at the bottom because it's reusable.
Anyways all the parts finally arrived, and upon reassembly I noticed something. Every video I watch, you install the parking brake loose then use the adjuster through an access hole in the rotor. My car does not have that access hole, does this hub look aftermarket? In all the videos peoples hubs have multiple holes that clear through and mine has none so the adjuster cannot be adjusted
The black hole in the the photo is not an access hole, it doesn't go straight through.
Anyways the issue that I'm having is that I don't have a tool to measure the inside of the rotor and the diameter of the edges of the shoes to get this accurately within toyotas specs.
When I pull the bell crank from the back, the shoes only spread maybe 2mm, is that normal or did I install something incorrectly?
