Issue with ABS (I think?)
NexusD
SF Valley, Cali
It’s been a long time no posting for me. Well to get back into the swing of things I may have a problem with my ABS system in my 97 LX450 with 121k miles on it. This past weekend I did a rear axel work up with new break pads, rotors, bearings and seals. I also pulled and cleaned the ABS sensors. Everything went ok until I took the LX out for a test drive. All was ok until I came to a complete stop, it seems that the ABS kicks in a little too early and it’s only on a full and complete stop. For example, I pull up to a stop sign, I start to press the break petal, when the LX comes to a stop the break petal kicks backs with a buzz and a feeling like the ABS is kicking in.
Can anyone help me out with the diagnosis of this issue? It’s driving me nuts and is it safe to be driving the vehicle like this?
Any help would be greatly appreciated
Thanks, Danny
Check the front sensors. The ABS system looks for a difference in wheel speeds. It might be that with the rears clean the fronts are sensing a difference. Mine was doing that exact thing, but mine was the rear sensors caked up with shavings.
ABS issue
Ok so the other night I took apart my ABS front and rear sensors. Yes they were dirty so I cleaned off the all the old junk. Put everything back together, took the LX out for a test drive and I’m still getting the same issue as before? Mind you it’s not as bad, but it’s still having trouble.
What to you guys think it maybe?
oh and i Locked the center with ABS off and everything is fine, just like normal. It's the ABS some how??
TM;
(not to hijack the thread) I have never had my ABS sensors out;
anything in particular to watch for when pulling them out? Do you suggest routinely pulling them and cleaning them??
I have noticed that my ABS seems a bit "twitchy", ie: comes on if I use the brakes when going over a surface that is not perfectly flat, but not a panic stop. More so than say 100K ago.
G
I have the very same problem as you that i've dealt with for over a year. I cleaned (as best I could) my abs sensors with no help. I wouldn't say its dangerous, but it gets a little touchy in slippery conditions (ie. snow). I wish I could offer some help. maybe by bumping your thread up someone might chime in. good luck.
I've had this problem for years as well. I might go months without it happening, but it always returns. I will usually get an ABS warning light after it happens that will reset itself when I turn the engine off. Borrow a sensor from a fellow ihmuder (or buy a used one) and see if you can isolate the problem to a particular sensor.
