I have a new issue I need help finding/diagnosing. 97 Supercharged LX450 with 212K.
In reverse under heavy load, such as backing up a trailer or backing up a hill I get a short grinding/binding noise that, quite frankly, is very scary. I would get a recording but I am not sure if this is causing heavy damage.
Describing it as best as I can it sounds like something is binding up and then when I lift off the throttle it unbinds. The second sound is a reverse of the first (hope that makes sense). It has a bit of metal on metal but also has a bit of twisting rubber squeak too.
The binding/grinding noise sounds like it is coming from right front and it feels as if this causes the truck to stop moving. The engine does not race so it is still under load, and the truck does not roll forward so there is still torque to the drive-line.
This has never happened in forward gears, only reverse and I even put it in 4lo so see if it was the TC.
TIA Eric
TIA Eric
