Getting started on a major coolent PM and now that I most everything torn down, I inspected the water pump on the engine. With only about 96,000 miles, I wasn't expecting to replace it, but now I'm not so sure.
It's been a while since I've played with a water pump, but I seem to remember that they are usually very smooth and make no noise when you turn them.
On mine, there is definately slight drag and it's somewhat of a jerky drag when I turn the pump. Also, it makes a constant sound, when turning either direction that sounds like a faint door creaking. I have no in and out movement and essentially no side to side movement. I mean can just barely feel a very, very slight movement if I push on it, but I think this is normal. There's no weaping that I can see.
Based on this, I'm pretty sure the pump is bad, but I want to get some opinions before I order and make sure this isn't perfectly normal somehow. Even if the pump is only starting to go bad, I'd figure now is a good time to replace since everything is apart and it's right there easy to R & R.
Thanks for any opinions.
