Is this the same?
Austin, TX
Hey - I'm doing a mini truck PS conversion on my '76 FJ40 and noticed when the truck was de-smogged they removed the brackets for the smog pump. Well - I need this bracket now for Lance's fancy laser-cut bracket to mount the Toyota PS pump. My question is, was this the same bracket as the F motor alternator bracket that used to be mounted in the same location. I've got one of those in the garage if so. I'm talking about the one that bolts beneath the DS motor mount and provides the swivel bolt ...
Anyone?
Tucker
The alt bracket is the opposite design than the air pump bracket....the alt bracket is a solid block that the ears on the alt straddle, and the block has a hole in it for the alt to pivot on....the airpump bracket has two ears and the pump has the solid block that fits between them....
They will bolt in the same place....the bolt hole spacing for them is identical, and either will work on an F or 2F block that has the holes under the engine mount on the block flange, beside the oil pan bolts.
Good luck!
-Steve
