Is this the PHH??
It looks like it may of been replaced sometime in the past since those aren't the factory hose clamps.
now have fun putting your hand in there to RnR!
I highly recommend not even screwing with those clamps. Just get some side cutters and start snipping. I used a very sharpe pocket knife to start the cut in the hose and then followed with a pair of side cutters. Use caution, go slow and make sure you do not bugger up the hose inlet. It is a PITA but honestly it isn't that bad. Give yourself time and enjoy doing a job that probably saved you a cool 1000 bucks.
CS
Most of us tend to replace with either silicone or Gates Green Stripe and use Constant Torque Clamps. I'm going to go ahead and be a bad sales person and link to both products on two different sites (to be honest you can't go wrong with either):
1FZ-FE PHH – Kit 1 or PHH Kits
Thanks for all the replys so quickly! It doesn't look to hard, it's just in a tight space. I'll try and knock it out tomorrow if I can get out of the office in time. I'm slowly replacing all the hoses that show any sign of wear.
Exactly. Don't bypass the metal tube; it keeps pressure off the heater valve up top and results in neater engine bay.
Cut the hose, undo the top bolt and top hose, and twist and torque the hard line until it breaks the bottom tab. (The only real PITA is attempting to undo the bottom bolt). Remove the hard line, then undo the clamps that hold it at your leisure.
Two notes: Be sure to clean up the hard line and repaint it while you have it out, and be darned careful around the knock sensor that is in there.
You may want to take this opportunity to replace the vacuum and radiator hose while you are there, as well as the fuel filter.
Enjoy!
Id bypass the metal tube as well if you're in there....
Why? I'm still waiting for someone to demonstrate how bypassing the phh pipe is in any way beneficial or easier than just using it as designed. OTOH, the PHH bypass adds side load to the relatively fragile heater valve and takes up more space in the engine bay.
CS
I asked my mechanic how much it would cost for him to replace this hose for me if I supplied the parts. It was under $200. I could not give my money fast enough.
My mechanic was a short and skinny Filipino guy at Enterprise Toyota (before I used K&H) and it cost me $85. Best sub-$100 mod I think I've ever done :flipoff2:
