Is this NORMAL?
Hi again fella's. I know this can't be the norm fo r a nice B.U.T. but I have to have backup.
This FJ40 build is really getting on my nerves....
How do I ID the model of engine I have? did 40's only come with F-2's? If so are they a rope rear main seal or is there an upgrade? I am dropping the pan tomorrow to clean and re-seal...
This is a pic of the flywheel bolts... The reason for this post....
FJ40s came with F (135,145,155, F and 1/2) and 2Fs. They all 1958-1987 have the same rubbery plastic seal. It is easiest to replace by dropping the oil pan as you plan and then dropping the rear-most crank bearing cap.
And of course, as Ige pointed out, you have to pull the flywheel.
Looks like a 1F flywheel, with mix bag of flywheel bolts. I'd git new bolts and tabs and replace your pilot bering while your there.
your Rear seal is a plastic/seal thingy on the other side of the fly wheel
....Dusty
Thanks
You guy's are brilliant... I DO know what the rear main is. LOL
I've been restoring car's all my life and did my first (a 1946 CJ-2A) in 1982....
Just never been in one of these blasted FJ Toyota's...
The clutch is brand new and looks just like the above clutch...
I'm getting new bolts tomorrow.
As far as sight-IDing a cruiser engine, here's a few helpful pointers:
F135 [pre 1967] siamesed port intake and exhaust with cast iron intake, press on harmonic balancer, raised ribbed steel valve cover, 1bbl carb standard, separate oil filler tube with or without PCV hookup [pre 65 did not have PCV]
F145 [1968-1969] 12 individual intake/exhaust ports, aluminum intake [wide runner] press on harmonic balancer, flat steel valve cover [no oil filler cap]1bbl carb standard 1968, 2bbl with air cleaner stud for early 69, side oil filler tube with PCV hookup
F145 [1970-9/71] same manifold configuration, narrow runner intake, bolt on harmonic balancer, flat steel valve cover[no oil filler cap], 2bbl carb with clamp on air cleaner, sider filler tube with PCV.
F155 [1/72-8/73]same manifold and carb configuration as F145, bolt on balancer, flat steel valve cover with oil filler cap, PCV valve mounts on side galley cover of engine.
F155 [9/73-12/74]same as earlier F155 except that the oil filter is no longer a remote unit connected by hoses to the driver's side of the engine block; it is now mounted via an aluminum bracket directly to the passenger side of the engine block, just forward of the distributor.
I'm sure others will chime in.;)
2F engines just say so on the engine boss behind the distributor!
hhhmmmm...i've never dropped pan/cap. it is kinda a pain too, maybe i'll try that next time.
Poser's suggestion. If you're dropping the oil pan anyway, it's way easier than beating in the new one from behind. Virtually no chance of screwing it up, too.
F..............and feelthy.
x2
You eatin' those buns? :D
Yes, you have a rare F135!
I don't have anything.... I'm restoring it for a customer... :)
Ahh. You're just replacing seals and gaskets and popping back in? How deep are you digging into the F?
