Is this diff a locker?
Salt Lake City, UT
Sorry for the bad pic, I just found an aftermarket switch in my cruiser and I'm trying to determine what its for.
Is this a locked rear diff?
1914228
Try taking a better pic. Where is the switch?
Are you trying to take a photo of the solenoid
It resembles one, but you do need to scoot further under & get a dead - rearward shot. The actuator sits high & left facing as you are in that pic, and under it is weird little bolt-on plate (acess to dog cog & fork) w/ either 4-5 bolts & the plate is roughly 2”x3”.
I think I see a bash guard over the actuator, not sure.
Do you see either a harness coming down to that high/left location, or a unused socket in the 3rd member in that area? -Other indicators of a locker.
That sure looks like an e-locker to me.
Any chance the door sticker has a K294 in the build code?
Or do you have rear disc brakes?
If you have discs, you have a transplanted later FF rear axle & what I see as a rear e-locker.
Great info Linus! That is not in the door code, but I do have rear disc brakes!
I always thought the disc brakes were installed by themselves. Had no clue it would be the entire rear axle.
So cool.
The switch is in a very weird place, take a look -
1914248
1914249
I want to say, having the words lock and unlock make it seem obvious now, but the location under the hood is why I doubted it and thought maybe it was a bad choice of words for a kill switch.
Haha, cool - to be completely sure you have a FF rear setup, you should have RR hubs that stick out a good 2” past the inner rear wheel hole.
If the hubs don’t stand proud of the wheel bolt-up flange, then it’s a semi-float.
But from looks & that ‘odd but waterproof’ -way of doing the rear locker, I’d be betting on a full-floater / later axle from the way it seems.
But my wheelhouse is really the ‘95-‘97’s as a whole, and I’m speculating on what some mystery prior owner did in your 80.
No matter what, I’d go to the closest gravel lot & power up that ammo can & flip the switch, -see if you can scrub tires on a sharp turn.
Also, don’t be surprised if it takes 50-80’ to engage the locker even doing sharp lock-to-lock turns, the RR design has big teeth that take some inequal wheelspin to lock comparitively to FR e-lockers.
It’ll be interesting if the PO also installed the lights in the dash cluster - you may need to be in LO range in the TC case to get it to work as well, depending how the PO wired it (so don’t freak if nothing happens in HI range in the TC).
I’m clueless if your generation has a CDL switch from factory, or how/if it’s a permissive as well since it’s a custom install.
Thanks so much for all the info, great stuff.
There is a red LED installed on the left side of the dash, I'm guessing for the locker.
We have a CDL switch and auto when in low range.
Here is my rear hub - FF?
1914255
Rusty and now I'll be doing something to protect it!
Yessir, you got a FF. Score!
And now you know someone just got a full axle disc to disc w/ an e-locker, so you have a axle worth the cleaning & painting!
Best of luck excercising that locker, if it hasn’t been cycled for awhile!;)
Yes, you have a 'swapped in' FF axle with E-Locker.
Someone went to a lot of trouble to cobble something together from things they had laying around.
Recommend you take all of that out...and do it correctly. Axle and locker are a 'score' though.
