Is there paint under trim??
Texas
Hey guys I’m really looking hard at buying a 1997 land cruiser the car is exactly this I really like it but really dislike the grey trim at the bottom. I’ve seen some exactly like this but with no trim all green. The question is can I pull this off and it’s paint underneath that matches the car?
That's a Lexus, all of them have the tupperware on the bottom. Find a green LC if you don't want trim.
Edit- Are you sure that's trim? Hard to tell from the pic. Might just be an LC with the bottom painted.
So I’ve found a lc ... this is the actual car, I just don’t like the trim at all saw one what was all green loves it just wonder if I can take it off?
I don't think that's trim, so not removable. You could take off the fender flares, but there will be holes.
Oh yeh just not a fan of the tubberware, so something like this came from the factory this way? Can’t just pop those off I guess?
Yes, LC's came in all-green. The two-tone may also be factory (I'd bet on it, but not positive) but there's nothing on the lower doors or rockers to 'pop off' on the two trucks you posted.
I kind of like the two tone
Ok on a side note it has 145k needs a new catalytic converter and the diff lock / e something isn’t working but isn’t locked in 4wd. 4wd will still work just not diff lock. How much do you think I will spend on the catalytic converter? I am not pressed or nor do I do a lot of off roading. Just making sure it’s not a bigger / more expensive issue than I realize
Hard to say, cats can be anywhere from $150 for aftermarket to 10x that for Toyota. Talk to your local muffler shop, or dealer if you prefer that route.
So just so I understand the diff lock being stuck will keep me from using the diff lock but I can still go from 2wd to 4wd, that’s what the gentleman selling the car said but I just wanna make sure I understood and he conveyed it correctly ?
It's a full time 4wd truck there is no 2wd unless an aftermarket part time kit is installed
Not an LX, they had darker cladding and the cladding had ribs to it. That’s a gulf states import, which were commonly done in two-tone.
If you remove the flares on a gulf-states truck the paint line is straight across and looks goofy.
Thats actually paint AND trim pieces.
So that LC has both the two-tone Dark Emerald/Moonglow paint (2AC) and has the gray trim pieces that just stick on like the 40th Anniversary and Collectors editions. Those peel off, there are no holes underneath, and it will be that metallic sliver paint underneath. You can remove the skinny trim pieces, but the silver paint is obviously just, there.
For the sake of correctness, there are holes under the '97 anniversary/collectors edition trim strips. On the doors there are two holes and just one on the fenders if I remember correctly from when I removed/re-installed a few of them on my truck.
The trim strips are attached with double-sticky foam tape and the holes are for alignment/installation I assume. The holes are elongated so that the strip can be position adjusted before you push it all the way down and adhere it.
Ahh thats good to know, I looked at adding some to my truck, and the ones I was looking to buy were just flat along the back without any tabs. But now I'm thinking they must have been aftermarket. And thats actually probably exactly whats on the OPs truck since thats not a CE or AE.
