Is there an ECT indicator light?
Fort Apache: Victoria
I just realised there's no light in the cluster indicating if my ECT is engaged. I know the ECT works because the shift points change when I engage the button.
'94 FZJ80
I guess it's burnt-out. No biggie.
does your yellow od off light work? they are on the same harness along with the p through d lights. I didn't reconnect mine properly when i reinstalled the speedo cluster after doing the temp gauge so i had none, i ignored this for a while until i figured out the od off light doubles as your at trouble code light so its not just a luxury.
That's funny because my OD light works. It's very faint, though. I can't see if it's on if I'm wearing sunglasses.
If you run with your lights on, your dash lights are dimmer.....
My lights are rigged to be on all the time. The only thing the light switch does now is turn the instrument lights and marker lights on.
Nope, it's not there. I double-checked just now. O/D light works, ECT doesn't.
Not a big deal, though. Next time I have it apart I'll have a peek. In no hurry to strip the console again, I tell you what!
reviving this thread because i have a quick question about the ECT switch. Is it supposed to illuminate?
I get the "pwr" in the cluster, but the switch itself is not illuminated at night with the lights on like the other switches in that row.
Most of the switches have little bulbs with a plastic base with a #2 phillips head on them. Easy to replace if you pop the switch out. I don't know if this is the same on the pwr/ect switch, but it's worth a shot.
