Even if it does run back to the next crossmember I'd cut it out and replace it with a tube that runs under both crossmembers. But that's just me having read up on proper design of trailer tongues.any last comments before I buy the dang thing? finally heard back from seller again, took a while, like 2 years...
I like the idea of running another tube inside the tongue, elegant and simple...
I have the same tongue design on my trailer. I found "The requirements for small trailers by the Australian Government" helpful and used it.
Here my uncommon tongue design. Not the norm but much stronger then the original.
looks very nice.
doesn't seem like you expect much wheel travel, eh?
) and a wet weight of 600lbs I dont think I will every use what I have. Thanks
Dexter torsion axle rated at 600-1000lbs. Torsion is progressive with 2.5" of up travel(same as a 100 series) and a wet weight of 600lbs I dont think I will every use what I have.
Spent a good amount of time on the trail with several different types of expo trailers prior to my build. I subscribe to Chris of Campa USA trailers theory that trailer wheel travel is over rated. Never seen/heard of a Campa trailer on its side not so true with the other popular trailer manufactures with fancy travel suspension. Most trailers with active suspension tend to load up when they hit a bump and don't have the rebound damping to control it and over they go.
With C rated tires, low air pressure, high tongue, low COG, and light weight my trailer rides well and stays on the ground.
Have you checked you tongue design with the AUS book yet?
The weak point would be were the tongue contacts the box, my guess. With that said sleeving the would help but an angle brace up, similar to my down brace would give strength in both up/down and side to side. Keeping the ability to 90° the trailer is huge IMO. My set up is 27' long and I can turn around in a 28' wide road.
