Is something loose in my diff?
I was under the truck today greasing it and I noticed there is a lot of play in my rear diff. I can rotate the driveshaft back and forth a lot and its moving the pinion flange. (Its not moving at the Ujoint) How much play should there be in there as measured from the outside before a tear into it. I compared it to my friends truck, mine moves twice as much.
So basically I'm asking how much movement is too much?
you didn't mention what kind of locker you have some have more play than others
shim this
you may need to shim the pinion bearing or the carrier so the ring and pinion gears have more tooth engagement
i've got the same issue and a bit of a ping when i engage the clutch. I plan on getting a third from the yard and polishing it up before swapping it in.
