Is it the same
HI 2 WA
I was just wondering if the semi float and full floating 3rds the same. Meaning i have the 2 rear ends and if i install it in the full floating axle and break an axle can i swap the 3rd into the other semi axle? Thanks
the only problem that you will found with the FF 3rd when you move it to a SF axle it's usually they don't have space or " window " that allow you to fit c-clips in place ..
That what happen with locked 3rds and LSD 3rds that we have down here ..
Mahalo to the both of you for the 411
