Is a V8 conversion "realistic?"
dnp
Supporting Vendor
Jackson, MS
I performed a search, but I didn't find the exact information I need:
I am working on modding a locked '95 LC, but right now, the engine has "issues." I had a locked '97 a few years ago, and as much as I liked it, it really just needed more power. I've been driving 100's for about 5 years, and the drivability of the 2UZ is an order of magnitude better than the 6 cyl. While I know there are other alternatives out there (SC, turbo, etc.), I can't seem to get the idea out of my mind to convert this truck to a V8 (probably a SBC, due to costs)..........all that being said, I can't seem to find a comprehensive "kit" to accomplish this goal, and the last thing I want to do is end up with a project that drags on for years and ends up costing thousand upon thousand of dollars.
So, am I missing something out there? Is swapping in a V8 (if not a SBC, then what?) a really big task or are there enough parts out there that, if collected in advance, makes for a pretty smooth installation? Are there any detailed explanations out there from those who have successfully made the swap? Conversely, is this a huge undertaking that I should abandon the idea of before I get started? Again, I don't want a big 'ol stupid project (20 years ago I might have dived in), so if I should drop the idea, so be it. I just need some guidance on this question, because I don't want to straighten out the 1FZ if, in fact, there's an "easy" way to convert this truck to a V8 (which Toyota ABSOLUTELY should have done for AT LEAST one model year).........
I figured if any group of people would know, MUD participants would; therefore, thanks for any advice you can offer.
Regards,
David
said and done about $4-5K for me, actually im looking at a 2" lift at the moment for clearance issues. took a couple months to get it done, it is an investment that may or may not be worth it depending on your situation.
There are a lot of threads on here about this topic. It can be done, but it seems like you have to have a ton of mechanical knowledge in order to chase down future problems and tweak everything to get it how you want it to perform. I remember looking at a company in CA IIRC that does V8 conversions if you don't want to DIY.
It is really nice to have a factory motor and have it function exactly how Mr. T designed it to. It makes chasing down problems a lot easier, it's easier to have someone work on it if you can't, and parts are available from Toyota.
From what most people say, a Supercharged 80 will keep up with a 100 series and will still be able to smoke a stock 80 even while towing a 3000lb trailer per Romer. Mine feels more like a V8 with the S/C. I can't speak for turbo's, but I am sure most setups are even more powerful and efficient.
In the end it depends on how much you are willing to spend in both time and money.
I dont think the demand in the market as warrented a "kit" but i believe youll find most cruicial pieces available thru vendors such as advanced adapters and I would spend on a few month research and collection period before turning the wrenches. There are several on the board... and a believe a discussion on which is the easiest swap (motoloco perhaps) . They range from Kirk's LS1 to white sharks 350 and everywhere in between. Extremetoy put the UZJ in the 80 if youd like to research that option of keeping it familiar to you and toyota.
Nothing is "realistic" with these vehicles. They are old and expensive as a hobby (though I can think of many more hobbies that are "unrealistic" as well).
That said, my preference would be to keep the powertrain Toyota. As much as I like the idea of a big American V8 in these trucks, if I had the money and time and energy, I would go with a Toyota diesel...
After all, if we wanted a reliable vehicle, why did we get a Toyota as opposed to a Ford?
If you are going to do the work yourself--depending on your skill level as well as what you want to do--you should plan on at the very least spending a good $5000. If you are going to farm out the work and the like, you can double that amount easily.
Cheers.
-onur
Nothing is "realistic" with these vehicles. They are old and expensive as hell, very time consuming and grey hair inducing as a hobby
Fixed that for you :cheers:
I dont mean to knock the toyota motor, but if you are looking at getting maintenance or repairs on a 3fe compared to a SBC in your cruiser, i think your going to have to admit there are going to have an easier time finding parts at the nearby parts store, and the prices are probally going to be better too. I wanted TBI for mine to keep it simple, if you were on a road trip and had to drop it off at any mechanic on the way, which motor do you think would be repaired quicker and cheaper? Put another grand or two into parts for the 3fe and then think about it, thats what i did before going to the TBI SBC.
You are right about a SBC being more widely known about and probably easier to fix by your everyday mechanic than a 3FE or 1FZ-FE. I was referring to having a mechanic fix something that is related to the actual conversion, like wiring problems or maybe fuel delivery. I considered a SBC conversion a while back but it seemed a bit too cost prohibiting and time consuming at the time for my cicumstances.
I think Beno is right on about the diesel conversion. It would be nice to have extra torque for towing and increased mileage to boot. Alan Podvin did a sweet duramax conversion on a 100 series 6X6.
I think Kirk's conversion is an LT1. Big difference between that and an LS1. The LT1 Optispark (or Opticrap) has issues with failing due to moisture buildup. Also the LS1 has individual coil packs per cylinder, better flowing factory intake/heads, much better PCM, and is simply better technology.
A 5.3 LS1 (truck iron block/alum heads) sells for under $1K all day long at the junkyard complete (PCM) with all accessories/harness/computer etc. They get better gas mileage than the 6.0 and make similar power. The 4.8 is a complete POS and not worth buying or using in the conversion. Stock the 5.3 puts down over 300hp and gobs of torque. With a stock Z06 cam installed (used under $100) and upgraded valvesprings (around $100), headers, better air filter setup, tuned PCM it should make closer to 400hp and pass smog easily. That is what I would do. You can also turbo these motors and make a reliable 500-550rwhp in stock form with upgraded cam/springs/injectors/tune.
Always think about the next weakest link as well.
Will the tranny hold up to a good SBC, or will it need work as well?
I have never been in an 80 with a SBC, but i would love to do it to mine. I think it really has to be something that you "want" because I don't think there is a practical reason for the conversion.
A friend has a (REALLY) sweet FJ-62 with the Vortec 350 and a 4L-60E tranny. Sure it has more power, but not a huge amount. It gets a little (VERY little) more fuel mileage than the 3FE, but it has taken several years to get confident with the conversion. It seemed like there were all kinds of little problems that kept coming up, and the truck is just now becoming reliable.
Now the Duramax.....THAT would have to be one hell of a truck!!!
There are some very good points in this thread, my 3-link v8, nv4500 project 80 has drug out due to building 3 other fj40's recently, not due to it relly being that hard (well the 5 speed is a little more tricky). But, I should be back to work on it soon and will post pics and thoughts. I really like the idea of a SIMPLE TBI, I also like the idea of a 5.3 or 6.0 with better power and MPG but a more expensive loom. They will not be as solid as a toyota power plant but who is going to put 300k on a built 80? And if you do, it would be a cheap and quick motor replacement once it has a V8 already.
