Is a 92 worth keeping?
Arizona
Hello, I'm a new cruiser owner. I've always wanted to own the iconic cruiser. So early this year I bought myself a present and pickuped up a 92 with 190,000 miles and in great shape. It already had 33" tires, a real wheel carrier and a 5th 33" and a brushguard. I bought the cleaniest truck I could find.
I should have done my homework. I didn;t know that the 90-92 models are really under powered. So here is my question? Is there anything I can do bo improve my power and MPG to the 92? Or should I sell it and buy a newer model.
Currently it's not my daily driver. But I think I want to ditch my little car and make my cruiser my only car. Is 15mpg possible in an 80? Im curently getting about 12-13mpg. HELP? And can I boost the power? It's a dog!!
1. Turbo
2. Motor swap
What do turbo's run?
dont expect to get much better gas mileage no matter what way you go, i think 15 is maximum, i put on a high flow muffler didnt get much increase, i would say that i average about 12-13 city with the muffler and it was about 11 before. so the easiest way to quickly increase your mpg would be a muffler, pretty cheap and definatly improves air flow, best of luck.
The decision has to be yours. I would not make any 80 (FJ or FZJ) my DD if I needed to get 15MPG on average.
Boosting power significantly in a 3FE is a very big project. A turbo is pretty much a custom job. Small block V8 is a custom job. Both are expensive. If $15k for an engine swap doesn't scare you off and if you need high MPG then your best option is a diseasel swap (can't believe I am recommending that... I hate them.)
A stock FZJ80 will get ~13MPG in city driving, 15MPG would be a stretch.
Good luck with your decision. The FJ80 with the 3FE is a great truck. It just needs larger brakes and wheels, and an understanding owner. For off-roading, add lower gears, larger tyres, an appropriate lift, and ARB lockers. You will have an excellent off-road vehicle.
-B-
are you correcting for the larger tires when you calculate MPG? - It should be off by around 7% with the 33's vs. the stock 31's - so you may be doing better than you think.
If you want to save some weight and ditch the rear tire carrier that would help also, I'd be glad to take it off your hands.
Selling it for a mileage gain would be a no win. The 3FEs had 155 hp and the 1FZEs at 212hp weren't really rocket ships either and both produce about the same mileage. Selling to upgrade to one with lockers (if you need them) would be a smart move. If you like this truck keep it. Engine conversions are expensive, you will never recoup the expenses of it by saving in fuel. I shouldn't say never but it will take several hundred thousand miles to do it.
I like the truck. And trying to sell it and buy another is a pain. Would I get any preformance enhancement or mileage improvement from better plugs, a KN filter, and an exhaust? Just looking to squeeze out a mile or two more MPG and a tad more hi end power.
Also I currently have 33x12 on cheezy after market rims. If I went back to stock wheels and 33x10's would I see and difference?
Some, not much. My guess would be less than .5 MPG. Unless the tires you have now are big lug mudders and you're moving to an AT type tread.
How about some pictures?
You mentioned a swing out rear tire carrier and a 'brush guard'. This wasn't a standard option in the US for '92. If you have that and 33" tires and a rear carrier... Any chance that front 'brush guard' says ARB on it anywhere?
Post up some pictures and we can all tell you what you really have for accessories.
If you thought it was powered OK when you bought it and are having fun with it, keep it. The '92 has a few features you won't find on the 'newer' styles. These are some serious fast food advantages.
You know that front cup holder that you can put a McD's 'medium' drink in? Forget putting anything larger than sunglasses in there on a '96.
That big shelf of a dash on the passenger side where you and your significant other set up the fast food picnics? The '96 gets an airbag and no more shelf.
See the clock with an alarm function? It gets dumbed down on later years.
Are you tall? The early model cloth seats feel like they give 2" more leg room.
Look underneath. See that shielding plate on the transmission? It isn't there on later models.
See the OD D 2 1 on the shifter? The later models get a more confusing D 2 1 and a button on the side for OD.
And no, I won't trade either of my '96s for it.
Now how about some pictures of that truck?
Converting to part time 4wd would make a difference. I get 15 mpg with my 62, and can really feel a sluggish difference when the front is engaged. Synthetic fluids in the diffs and transfer may make a difference. Make sure you keep your tire pressure up too. That helps. I would stay away from K&N.
No such luch as the bush gaurd being and ARB, I wish. It is better than nothing though. The rear tire carrier is an Assuie brand. I know they are covented and hard to come by. But it is actually a bit of a drag for me. WhenI do drive truck Im in and out of the back. Bikes, dogs etc.. I can be kind of a pain. I have often thought of selling it. I'll get some picks up and have you guys tell me what you think.
