Hey guys,
I recently installed the Ironman Adjustable Bushings and I had resized their .PDF template to actual size (185mm between holes), so when you print these documents you can actually use them as a template on top of your control arms.
This is the template for maximum height lift 3" - 4" , which should yield a 3.5 Degree correction.
These templates will print in normal Letter size paper, just make sure there are NO resizing options selected in the acrobat print options menu before printing and they should come out to a perfect fit.
Just before you print verify the "Print Scaling" option in acrobat is set to "NONE"
Just wanted to share and hopefully make someone elses install go smoothly.
