IPF 968 lights: Question on installing the 100w bulb
Colorado
Anyone here install the optional 100 w bulbs for the IPF 968s? [This may apply to any of the IPF lights, I suppose.]
I installed the 968s this afternoon without problem.
I'd like to use the included 100W bulbs, but now I'm stuck. ARB/IPF offers no instructions for switching/replacing bulbs.
I removed all appropriate screws to expose the light assembly, but I'm having difficulty removing the 50w bulb. It's attached via a blue wire to the light harness somehow within a staple-crimped, white sleeve. It doesn't seem to be plug and play. Do I have to uncrimp the staple and slide the sleeve to expose the connection? Or is there a more simple method?
Anyone with suggestions?
I just did this very thing last night. Just simply uncrimp the little wire with a pair of plyers. It's nothing more than a way to keep the sleeve on so it doesn't short out. Then remove the sleeve and unplug light, plug the new one in.
The only difficulty I had was the wire thing that holds the bulb into the housing did not want to come undone very easily. I had to bend the little taps holding the wire bulb holder out of the way.
I did mine a bit different. I cut the connector off the wire coming from the bulb and crimped it directly to the wire from the harness that I ran into the light housing. I put a new connector on the ground wire and attached it to the base of the lamp. wish I had a camera.. reading it back, I'm not sure I explained it clearly.
so was the difference between both bulbs significant? I have wanted to do this for years, but didn't think it would be a major difference. I've had these little 100W bulbs stored for the longest time now..
so was the difference between both bulbs significant? I have wanted to do this for years, but didn't think it would be a major difference. I've had these little 100W bulbs stored for the longest time know..
Lights will be a lot brighter but the penalty is a decreased bulb life span.
Thanks for the replies and tips, all.
:cheers:
