"Intro" post for 91 80 Series
Bonney Lake, WA
Hey everyone!
I have owned it for 10 years and it has run like a champ. All mechanical and electrical is original with just over 200k miles logged on it. It's a family daily driver with a few road trips, camping trips and a few trails completed in the winter in the PNW.
What has been done:
- 2.5" OME medium suspension
- ARB Front Bumper
- ARB Side Rails/Steps
- Frontrunner Rack System
- Frontrunner Rooftop Tent
Now on to the reason that I joined. With it being almost 30 years old and all mechanical and electrical being original I plan to take this year to slowly get in front of the curve of parts failing for simply being old. That is what a local 80 Series shop here in Washington, Torfab, suggested. I'll be doing the work myself, with the help of my Dad and Brother-In-Law, we all have 80 Series.
With that being said. What do members here suggest I start with first.
Thank you all and I'm looking forward to participating in what looks like a awesome community!
anything critical or borderline critical and also made of rubber. i.e. caliper kits (or replacement), brake flex hoses, all coolant hoses, fuel hoses, and then there are all the seals, 0-rings and gaskets to consider. I have just received a big order from Dave Steadman at Japan4x4... all in was about $1500 Canukistan Kopeks... The tranny rubber and gaskets came in at about $1000 My 80 is also 91 RHD JDM and I'd be happy to share the parts list with you. OEM only, no Chinesium allowed on mine. Good luck and keep us posted on your progress.
What's the history on front axle service? If you haven't done it in 10 years, it's due unless you know the previous owner had it done right before your acquiring it...then it's still probably due.
If you're on the original coil springs, you'd be surprised at what a difference new ones will make. Sticking with stock height coils permits an easy install with no need for caster correction. If your truck has no excess weight requiring extra dampening, the OEM Tokico shocks will round out a nice freshening of the suspension.
Thank you greentruck! I would much appreciate the parts list. I need to replace the Steering Pump and the Catalytic Converters next and then I'll jump on what you suggested. Do you have any suggestions for a Steering Pump?
The definitive thread can be found linked under the FAQ sticky here on the first page of the 80 forum.
Front Axle Rebuild - For FAQ
It's worth a read. Somewhere in there is IIRC a link to the file that has the front axle cheat sheet. It has all the parts listed.
Slee also has some excellent guides to the 80. The install guide for the suspension is worth a read.
Slee - OME Suspension Installation (Toyota 80 Series Land Cruiser)
Not sure what's up with the ARB 4x4 Accessories | North America office website. It's just a bunch of links right now that take you nowhere except for a pic of an ARB-equipped 80. What you want are the 861/862 coils (2 of each for front and back ends) plus the OEM Toyota Tokico shocks. You don't want the LX450 OEM shocks unless your're looking for a Lexus-style ride (sic) FWIW.
Thanks 80JDM! I would love the list. I'll be working on all "soft" parts come the end of spring. Do you have any suggestions on a steering pump? Being a 91 it's very different than anyone with a 93 and newer.
Why do you want a steering pump?
Heres the list of parts i have bought so far. Never mind the colours and sorry it wouldn't let me attach a excel file.
Hey James, welcome to the site!
I'm in a similar boat as you. 91 with lots of miles and I'm playing catch-up on maitainace. I'm in Portland, OR. I've got a 93 I'm parting out if you need anything.
Agreed with everything said. Good time to replace your axle seals and bearings. Make sure to clean out / replace your breather tubes. This can be done at anytime really. If those get plugged you run the risk of blowing the seals.
I'd add a tie rod end replacement to your list. Buy, steal, or borrow a tie rod puller. They are free to rent from most auto stores or they are $35 new and worth every dollar. The pullers are worth having if you blow an end while wheeling, you could even keep your current tie rod ends for spares. Oh and make sure you have a vaccum brake bleeder. They are like $18, it will save you hours.
Probably time to replace your O2 sensors.
Make sure to swap out rusted nuts and bolts as you go. A good penetrating oil and patience is your friend with bolts that haven't moved in 30 years.
