I've got a head scratcher??
Have a freshly rebuilt (0 miles) 350 V8 (Carb) in my 76 FJ40. Ran if for 1/2 hour @2000rpm to break things in, idled it down and set the timing & idle. Having a problem with it intermittently dieing. When I first got it started and was adjusting the idle up to 2000 rpm's it died. I started it right back up and ran it for 1/2 hour with no problems (55 psi oil pressure & 195 degrees). I then idled it down and set the timing & idle and it died a couple more times after running for a bit (10-15 mins). Fuel filter is staying full, but was wondering if I might have a defunktive mech. fuel pump. I've tried a new Holley truck avenger carb and still have the problem. There's no specific time frame as to when it dies and sometimes it doesn't die between long checks. FYI, running a new Accel HEI.
Any thoughts?
Any thoughts?
