my driver side window has always been fincky I replaced regulator and motor from used cruiser bout 7 months ago. Worked great for bout 4 months then back to having to smack the door and would work again. So I took door skin off and pulled motor and regulator as one and went thru it all.
1. Pop your switches out and disconnect
2. Undo the screw out of the handle
3. Pop the cover off the armrest and there will be two more screws to pull
4. Pop off the triangle in the upper corner of the door and remove the plastic trim under door handle, pull the lever open then remove so you don't crack it
5. Next you will have to pull the skin off the door gently pop around the door to loosen out all the plugs and oil back the vapor sheet
6 lower the window almost down to where you can see and get out the two 10mm brass bolts off the window track that holds the glass
7. Lift the glass up out of the door tilting it slightly and out the door
8. I then undid the upper two 10mm bolts from the upper track off the regulator
9. Disconnect the motor them Undo the four bolts 10mm that hold the motor and regulator. The whole regulator and motor will drop out and remove out of the big hole in the door.
10. I then disconnect the motor from regulator and found the gear in good shape, plugged just the motor in and it ran fine no problems. Looked over the regulator and cleaned up all the old hard grease from where the regulator teeth mash to the motor gear. I then notice where the spring on the regulator is that there was bunch grime and dirt between the two pieces. I degreased that area and sprayed bunch kroil between the two pieces and on the spring then cleaned as much dirt and grime out from under the two pieces. Dried it out and put all back together. Then tested with the motor back connected to the regulator ran it out 50 times with no issues. Between where the spring connects the two pieces and the gear area of the regulator I cleaned it all up of old grime and grease and scotch brited the gear of the regulor. There was still plenty of grease on the gear teeth of the motor which I left alone. Put back into the truck and slide the glass back in. Window now works great and is very fast. Put the door back together took bout hr to do the whole thing
