Intermitted 3FE problem
Afton VA
A while back the truck (91 FJ80) was running a little rough and developed a light miss or dead spot while in Drive under load ~1900-2000 RPMs. If I drop it back into 3rd it runs fine. Plus sometimes, as I’m going through the gears, there is slight stumble then all the sudden all cylinders kick in and it runs fine. Over the last month or so I started looking at things and doing some maintenance hoping to resolve the miss. What I have done so far is;
Check, rechecked, triple-checked for vacuum leaks.
Replaced plugs, Wires ,Cap & Rotor, air filter.
Adjusted Valves
Replaced fuel pump screen
Removed & cleaned throttle body & EGR Tube
Component Test & Adjust (if necessary) EGR, TPS & MAF
Did the Seafoam cleansing plus ran 2 cans of 44BGK through the tank.
Check cleaned all connectors, fusible links that I could find.
Adjusted tranny & throttle cables.
Overall the truck is running much better with good power but I still have the slight hesitation under load.
Any ideas where to look next?
Thanks,
JC
Couple of things come to mind.
You said you checked for vacuum leaks, but did you check for clogged vaccum lines? Carbon deposits along with disintegrating rubber from the EGR valve diaphragm will clog the array of hard lines that run behind the 3 VSV valves. Also, don't be shy about replacing 16 year old vacuum lines with new ones. The majority get crispy as they're sitting above the exhaust manifold.
On mine I had a similar situation where the motor would really lug until 2200 RPM and then it felt like the turbo kicked in. That was a failed EGR valve. I replaced the valve and EGR modulator (2 flying saucers on the left side of the intake) and it made it all better.
Also the intake plenum can develop cracks along the bottom and allow unmetered air into the intake. This can cause stumbles at idle or even stalling if severe. Usually, as soon as you come off idle this will clear up, but it's worth a looksee anyway.
Thanks, I’ll take a close look at the EGR components, Vac hoses and plenum.
I have read some threads about the injector insulation on the injector harness getting burned away. Is there a way to inspect this without removing the plenum?
