Oner of 2000 LC for 2+ yrs, great truck, but having an intermittent starting problem. 90,000 miles.
Here's the symptoms:
Out of the blue, 1-2 times a month I go to start the truck. Sometimes the starter turns over very slowly for 4-5 revolutions & then nothing. Then I continue to try & it cranks full speed & doesn't act up again for maybe a month.
I thought maybe neutral safety switch, def not the batt.
It seems as though sometimes if I hit the brake & shift in & out of park it starts. This morning nothing, even following the above sequence. I reset the neutral switch on the console & nothing, just idiot lights & warning buzzer.
I just kept turning the key on & off & all of a sudden worked fine & continued to restart thereafter.
Last time I had it to dealer for other service they could not find the prob as it was operating fine.
I don't want to spend $500-600 to "see" if it's the starter. I checked battery cables, but could not even get to the starter connection.
Any ideas?
Sticky starter brushes? Can I access the starter from below & remove the rear cover & spray some contact cleaner in on the armature to test that theorey?
I here the starter is buried under the exh manifold & a bear to replace.
Any help would be appreciated.
